eXcelon x600f 4 channel mint
destined2race
Already Being Used....
Kenwood Excelon series x600f 4 channel amplifier
Absolutely mint, only a few months old was not bstock, bought online or anything like that. I could easily say never used it looks fresh out of the box. Bought from a local store.
•4-channel car amplifier
•100 watts RMS x 4 at 4 ohms (150 watts RMS x 4 at 2 ohms)
•300 watts RMS x 2 at 4 ohms (4-ohm stable in bridged mode)
•CEA-2006 compliant
•MOSFET power supply
•variable high- and low-pass filters (50-200 Hz, 12 dB/octave)
•variable bass boost (0-18 dB at 40-100 Hz)
•preamp inputs and outputs
•cooling fan
•fuse rating: 40A x 2
•4-gauge power and ground leads recommended — wiring and hardware not included with amplifier
•14-15/16"W x 2-5/8"H x 11-1/2"D
retails at $400, seen a few on ebay new at $288.00.
Kenwood Excelon X600F 4-channel car amplifier — 100 watts RMS x 4 at Crutchfield.com
$200 plus shipping.
will use whatever shipping method buyer wants. I thought i kept the original box... ill keep looking, otherwise not sure it will fit in a flat rate.
My Focals would like this a lot! Hmmm.... Might have to have it. Glws till I figure something out.//content.invisioncic.com/y282845/emoticons/up2something.gif.dd110ecf3ae4b76050d87598f2f8de7c.gif
This is still a very nice Deal package for an entry level amp set up for some quality amps for the money...
18
Aslo, if you use your head unit for phone calls, read through the manual so you can set the speakers to use with bluetooth calling to front. Trust...
148
381
destined2race
destined2race
Beatin Down Yo BLock
destined2race
maylar
    Jun 2, 2024
    Jun 1, 2024
