HELP ME PLEASE!? Kicker L7 making "Rattling sound"
um, tma amps, are jl amps....... if memory serves right, the bass boost on those boosts the gain from something like 100-30hz, but not above and below. so, it's like setting lpf and ssf slopes
yah, what is the specs on the box? get some excursion video with sweeps. try and use a camera without blur correction... all these new phone cameras pizz me off
16 1/2" Tall X 21 1/2" Wide X 18" Deep
are you sheetin me? you are netting less than 2 cubes for that sub.....vented....... you need to build a box 3-2x that size. 6cu. net + port is what the sub really wants, and anything under 4.5, it's not really worth running an L7. 3 is the bare bottom you should go.
That's awesome. I used to be big into car Austin the '90s. Since then I have always had some sort of mild system for my wife's vehicles, but...
The sound deadening is going to be more about preventing vibration from metal surfaces and adding unwanted noise. Does it have the JBL system...
It's called the K.I.S.S. preciniple ("Keep it simple, stupid!")... Takes the guesswork out of parallel/series wiring.
ktwagner
ktwagner
Novato, California, United States
slvrado28z
