Help with dvc sub wiring
  • 2
bigman357
MN
I have a lanzar vibe 800 watt amp with four channels, the lowest impedance is 2 ohm, is bridgeable at 4 ohms. The subs are 2 4ohm dvc IX-12s. I am looking for the best sound quality and efficiency. Any help appreciated!
Not the best matchup. You'll have to run each sub in series at 8 ohms. 4 channels are like the worst way to power a sub. i'd strongly recommend switching to a mono block
Hello I'm happy to have came across this forum as I'm hoping someone will help with this little bit of confusion I'm having and maybe save me some...
Sure, 600 volts, yep. If you’re trying to launch the subwoofer cones to the moon! And, that’s if they don’t just vaporize first!
34
4K
187
460
bigman357
bigman357
MN
Buck
