Home Audio (sorry)
Im not goona get car subs, build an enclosure and just put 50W into each
That Lanzar amp is garbage and will only put 50 watts to the subs anyways.... //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
It'll just be more hassle to run than a home amp would be
as stated, you need a home subwoofer amplifier, they make them in rack-mount and plate-mount. the plate-mount are cheaper but have lower power. for the same cost as a power supply capable of 25A at 12VDC you can get a 300W plate amp that directly plugs into the wall socket (120VAC) and has auto turn-on and crossovers. Parts Express and MCM Electronics are where I buy my plate amps. they push subs surprisingly well because the house has more power capability than a car.
I haven't had a proper home theater or home audio system in quite a few years but here's what I remember. I like both systems to perform the same...
14
Hey guys didn't realize this thread got revived. Decided to bite the bullet and buy a used Yamaha receiver. 6 channels 100 wats per channel with...
13
Here is the plan. My car is on a bit of an incline, the nose is sitting about half a foot higher than the rear. The little bit of windshield...
667
I was browsing parts express. It seemed like around $180 for a 300 watt plate amp. The dimensions are not identical, new amps seem larger by a few...
chriszandler
chriszandler
New York City
keep_hope_alive
maylar
    Jun 2, 2024
    Jun 1, 2024
