hooking up 2 amps
hydrone
Learner
hey i got 1 sony xplod 500w 4 chanel amp and a kdx audio (cheap one i suppose) 2x130w. my question is this; can i connect the two and have my speaker and sub running off both or should i have the speaker on one and the sub on the other... either way is it possible to conectthe two or do i have to run separate cable ie power remote and rcas? please help out guys!!
you can not bridge the amps together. Does one of the amps have an out put for rcas. Your going to need a distro block for power wires.
u need a fuse block for power wires, ground block for ground wires. U will need to run separate RCA's for each amp, as for the remote wire u can just same one. just run from one to the other, then a wire from battery to 1st amp
depends on what woofer and speakers you have. to be honest that amp you got was junk for a 4 way. i would get a different amp. post up some product numbers and specs.
382
523
Hello all. Used to come on these forum quite a bit. I used to compete in IASCA MECA etc. and placed 1st 2x with this setup. Anyway this is my baby...
You don't need two amps. The speakers come with crossovers to help protect the tweeters.
14
Perhaps you changed something without mentioning it here? Maybe a loose turn on line? I dunno man...but we'll take it. Hopefully it keeps working. 👍
16
hydrone
Learner
hydrone
Arriate, Spain
brodeisel
maylar
    Jun 2, 2024
    Jun 1, 2024
