How much on stk electrical ?
From what I've always been told around 1500 rms is the most you want on stock. Of course that can change with your stock alt size and battery choice. Personally I have a stock 150 amp alternator with the biggest agm battery I could fit under the hood with no big 3 and have 0 issues. I am running an IA 10.1 (1200 at 1 ohm) and a Diamond D5 600.2 (class a/b 150x2 at 4 ohm) for comps.
Yeah, seems that's what I had seen . About 1500 . Thanks
Sent from my SM-G935V using Tapatalk
---------- Post added at 04:36 AM ---------- Previous post was at 04:36 AM ----------
Its highly dependent on the size of the alternator.
How do I figure that out ?
Bout tree fiddy
Ha!
Sent from my SM-N950U using Tapatalk
Hmm , looks like 130 amp
i have 125 amp alt (get 14.7 or more volts at idle) and agm under hood no problems with over 900 but i think 1200 will be my max.. for 1500 just make sure your alt is good and u have at least 1 agm batt
Thanks ![emoji106]
Yea you can probably get 1500. I've got a Subaru Legacy with 1200 on the sub, 200 on the 4 channel and no problems at all, and I doubt Subaru was trying to put the kind of alternator in there that you could power a house with, if ya nameen.
Sent from my SGH-S970G using Tapatalk
Ive ran about 3k on a stock alt. But with big 3 and 2 secondary XS batteries.
1500 is generally the safe zone assuming stock alt is reasonable, and you at least do a decent starting battery.
They were awesomne man. The components and Coax speakers I shoulk have kept. Theyre amps were pretty nice too. I never ran any of theyre subs...
20
Buck, great idea. I did that tonight, and it actually didn't wheeze like a fat guy trying to run a marathon. I am going to put two windows that...
19
  • Locked
Oh, just for future reference. Put $800 OBO, or you will only get that $600, or less. ;)
If your audio system constantly draws more amperage than your alt produces, it will drain your battery, to the point of the battery needing to be...
14
The one and only mtx amp I've run was like that (it was black with the fake chrome platistic badging back in '01 I think) the first time I made a...
41
4K
OldHeadBASS
OldHeadBASS
N. Alabama
OldHeadBASS
