I need advice/help!
  • 2
Elliottcottrell
okay so my 2014 Nissan Sentra it comes stock with a 110 amp alternator. i want to put a high output alternator into it in place of the stock alternator, i have done the big 3 and i have 1/0 wire running to the back of my car in the trunk with a 2 farad cap. the problem i am running into now is there is a 110 amp fuse that is on my positive terminal of the battery under the hood that i am unsure will be able to take anything more then 110 amps from the alternator i want to put in it. i need help on what to do!
Your big 3 is incorrect. You're supposed to by-pass the stock alt to battery wiring. Get a AGM battery and ditch that cap.
27753
the positive battery terminal has a inline fuse that you can't bypass because there are five or take 10 wires coming out of the fuse from the positive terminal
i don't have a fuse going from the alternator to the battery, the fuse that i am talking about is the fuse coming off of the positive terminal of the battery post not from the alternator. it is a stock positive battery fuse
I thought you had a 110a fuse on your stock alt wire. You can do it from your alt or at the battery it doesn't matter. Your factory fuses will be fine.
501
Honestly, beyond what you need. It will do the trick for sure, but it is excessive. Not a bad thing, just more than you will ever need. No need...
thanks 1aespinoza for advice I decided to not use the blaupunk I got a real nice Pioneer.
608
Man, sounds great - no pun intended! Glad you're happy with those Morels, I think they are special. Not sure why they don't get the local love. I...
36
I'd also recommend that at the very least, you deaden the doors with some sort of mass layer like this Siless Max 120 mil (3mm) 30 sqft Car Sound...
892
Elliottcottrell
Elliottcottrell
tennessee
marc2112
maylar
    Jun 2, 2024
    Jun 1, 2024
