Interference from brake lights, signals, and rear defroster, Please Help!
tommy234
After installing a 4 Channel amp I'm getting a humming through all speakers.
It happens when I press the brake pedal or have my signal on and is much louder when I'm doing both at the same time. I also get a pop when turning on the rear defroster.
It gets louder the higher I set my gains.
I installed a noise filter which did absolutely nothing.
I am wondering what steps can be taken to try and narrow down what is causing this problem.
Any advice would be greatly appreciated
Have you checked the grounds? Maybe adding an additional ground wire from the Battery to the frame of the car? Or regrounding the Amp grinding the ground point to bare metal.
I was thinking of doing a big three upgrade when it gets a little warmer out. Also checking the ground on the HU. Ya I figured the filter wouldn't work either but it was worth a shot
EMR sniffer or AM/FM sniffer. small radio but with a probe antenna to it. It gives you the specific location on the ground loops. This device...
26
I feel like its a bad set(Low tier set) of RCAs myself. I use Stinger Zero Noise and 4000-8000 series without any issues. Dayton makes a nice set...
That doesn't make any sense. The directions say to hook it up to the parking brake. The parking brake is engaged when the car is off. You...
17
7K
tommy234
tommy234
Ontario
viwil
just call me KeV
    Jun 2, 2024
just call me KeV
    Jun 2, 2024
