COMPLETED JBL P180.2 180Wx2 Power Amp
  • 4
Pinkeerach
Price
$200
Condition (1 worst - 10 best)
10
Brand new. Only removed from box for these pictures. Never installed or used in anything.
The awesome-looking, die-cast chassis serves as a highly-effective heatsink to keep the amp running cool, even in high-stress situations.
A variable high-pass/low-pass crossover allows the P180.2 to serve in a variety of applications, from powering full-range speakers or components to driving a subwoofer. Heavy-duty terminals will accept up to 4-gauge power and ground wire, and up to 8-gauge speaker wire. If you use the speaker-level inputs, the amp will turn on when it detects an incoming signal.
Details:
- 90 watts RMS x 2 at 4 ohms
- 180 watts x 2 at 2 ohms
- 360 watts x 1 in bridged mode
- stereo or bridged mono output
- Tri-way capable (Tri-Way crossover required)
- low-pass/high-pass crossover variable from 32-320 Hz, 12 dB/octave
- accepts up to 4-gauge power and ground cable, up to 8-gauge speaker wire
- requires 8-gauge power and ground leads — wiring and hardware not included with amplifier
- MOSFET power supply
- preamp- and speaker-level inputs
- "Common-Sense" feature turns amplifier on when it detects signal through the speaker-level inputs
- dimensions: 14-1/8"W x 2-13/16"H x 9-1/16"D
40653
40654
40656
40657
Was Photo Included
  1. Yes
Man thats one of the best JBL amps ever made IMO. Be one clean front stage amp for sure. If I needed another amp, this would be a hell of a buy. Priced right. GLWS!! Nice!!
This is still available. The backstory is that my husband was putting together a bombass audio system for his Nissan 240sx. Right as all the pieces arrived, he got into tuning, and instead of installing the audio system (aka a bunch of extra weight), he spent time/energy upgrading the performance of the car. Over the years, we thought we might use this equipment, but alas, neither of us is into this hobby anymore.
I can work out shipping if you're not local.🥰
I didn't see where there was a difference (didn't see a "light" or "lite" version). That said, if you can fit it, then the JBL BassPro SL 2 would...
WANTED JBL 800GTI
Slava Ukraini, Brother! Don't have that amp but good luck and welcome!
I don't think this is ideal, but let's assume you can easily mount all the tweeters. That installing them is going to be really simple, and...
13
Working with undersized material, adjusting on the fly, testing before setting; you sound like and old pro. You are as meticulous as alot of the...
76
6K
Pinkeerach
Pinkeerach
Charlotte, NC, USA
Pinkeerach
