JVC 'KD-SC500' CD/MP3 head unit
  • 4
LimPerT
I installed this head unit myself and it never remembers my stations //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif. I reset the hu and reset the stations. It will remember them if i start up the car for like 5 minutes after i set them but if i let it sit for a while then it will forget my stations and it wont play the last song i was on in a cd. //content.invisioncic.com/y282845/emoticons/bawling.gif.6287aa5d1d447c8af063fc9466e822ef.gif
BTW I had to run my own constant 12v in a fusebox under the hood to the hu for it to work in the first place because my stock reciever was a tape player and it didnt have the constant power.
can anyone tell me what it might be that makes my hu forget my stations after my car is off for a while?
ill probably end up calling jvc but i wanted to see if any of u knew first //content.invisioncic.com/y282845/emoticons/tomatoface.gif.6507032fedd1868ec0a6a447bb29a18a.gif
-David
I can guess at what it is but can't say which wire it is. It is probably the memory wire that you haven't conected or have connected just to something that goes off with the car off. For that one you need something that goes straight from the battery. Check the instructions for which wire is the memory because I really can't tell.
just rewire it and see if every thing is honkey dorey //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
no problem.
Im here to help as much as i can.
//content.invisioncic.com/y282845/emoticons/imdaman.gif.bc6c552e19aa4ad8c47461144f40eb1a.gif
Google do it translate what ever i do
4
327
Hi, if no one here is able to help you figure it out, try over at diyaudio in the car audio section, it is a more technical forum. This is one of...
Usually when you shop for a replacement harness for your model, you will find the pictures may show you in what pins your wires go to.
Yes, the power wires' colors don't match from the dash to the new harness. However, I tested them and the wire I'm treating as the constant 12v is...
9
LimPerT
LimPerT
Grapevine, TX
Norcalracer283
just call me KeV
    Jun 2, 2024
just call me KeV
    Jun 2, 2024
