Kicker cvt 10 to port or not?
  • 4
jeramy88
So I am building a sub enclosure for my 05 f150 supercrew cab, it is .88 cubic feet down fire single 10" cvt 2 ohm sub powered by zx400.1 at 2 ohms and I'm debating on making it a sealed with poly fil or ported with poly fil or no poly fil. I'm going for sq and SPL too, just a nice low but clean bass.
Kicker recommends .8 to 3.0 cubic feet for sealed and 1.25 to 1.75 cubic feet ported and I have .88 cubic feet should I listen to these recommendations or will ported make this sub sound great?
Also not sure of hz I would need to tune it too?
All help is greatly appreciated!!
if you are not dead set on that sub, there are a lot of 8's that would shine in a ported box that size, and can be tuned pretty low. sundown audio, digital designs, cadence, skar, just to name a few.
---------- Post added at 10:42 AM ---------- Previous post was at 10:42 AM ----------
tuned as low as 30-32hrtz.
sealed boxes can be ok, i used to use them. then i got my first ported box, a 12inch rf t212 @ 33hrtz...never doing sealed again. some guys on here will rag on the kicker subs, but they are ok, especially if you already have it. some of the subs i mentioned are less than $150, but anyway, if you are restricted on space you can only work with what you have. as far as poly-fill, i can't speak on that, don't know enough about it. i think it has something to do with the sub "thinking" it is in a larger enclosure, something about slowing down the sound waves and whatnot.
824
jeramy88
jeramy88
United States
THATpurpleKUSH
maylar
    Jun 2, 2024
    Jun 1, 2024
