Kicker L7x or Rockford T2 13
  • 5
Guyver
What are your opinions on these two subs? Currently running a 15 Stereo Integrity SQL and wanted to try out these two brands. For a musical sub that can get down low and nasty as hell while pounding good, would ya go for a Rockford T2 13 or the new Kicker L7x Solo 12? Current amplifier is Rockford BDCP 1500 but going to upgrade to 2500 BDCP. Also between these two, which one is more power hungry?
I mean I would look at adire audio before Rockford or kicker but out of those 2 the Rockford would be my pic.
The SQL should be damn nice you might get more output with it ported or going to 2 12s port led if possible.
That sql 15 should smoke both the rf and kicker in down low output and sq
Adire brama would be an upgrade
822
Guyver
Guyver
St. Paul, MN
maylar
    Jun 2, 2024
    Jun 1, 2024
