Kicker ZX460 (ZR era)
  • 6
350zkid
1. Product:
Kicker KX 460
2. Specs:
2-, 3-, 4-channel output
Tri-way capable (Tri-Way crossover required)
30 watts RMS x 4 at 4 ohms
60 watts RMS x 4 at 2 ohms
90 watts RMS x 4 at 1 ohm
120 watts RMS x 2 at 4 ohms in bridged mode
180 watts RMS x 2 at 2 ohms in bridged mode
stable to 1 ohm in stereo, 2 ohms in mono mode
frequency response 10-28,000 Hz
MOSFET power supply
requires 8-gauge power and ground leads — wiring and hardware not included with amplifier
rear channel switchable high-pass crossover (100 Hz at 24 dB per octave)
discrete output transistors
silent turn-on/off circuitry
removable endcaps and logo plate
14-9/16"W x 3-1/16"H x 10"D
3. Description/Condition:
Works flawlessly, Missing one terminal screw and a couple small scratches/paint chips, no end caps. Very good condition overall
4. Price: :
$120 shipped
5. Pictures:
Are you looking to run it full bandwidth? If so there is a "full" selection on the crossover. Other an that, I assume so but NOT saying I know for sure
822
350zkid
350zkid
St. Petersburg, FL
350zkid
maylar
    Jun 2, 2024
    Jun 1, 2024
