Major voltage drop
  • 4
rada194
Okay so when I'm driving my car my voltage will go from 14.6 down to about 13 volts when I'm really pounding it. When I pull up to a stoplight my voltage will stay at 13.6 and drop very badly. So I've come to the conclusion I need another battery. We'll here's the thing. I have an advanced auto autocraft gold battery rated at 800 cca. Would that work and if so is it ok because I believe that battery would give off some kind of gas in the sealed environment in my trunk. Also how do I run that battery do I have to make a second 0 guage run or what?
And just incase my system is 2 12 inch pioneer subs. Pushing 500 RMS. In a custom ported box that I made.
What amp are you running?
---------- Post added at 06:21 PM ---------- Previous post was at 06:21 PM ----------
And what's factory alt?
---------- Post added at 06:22 PM ---------- Previous post was at 06:21 PM ----------
What amp and what's the factory alt?
Okay don't laugh. But it's a lanzar htg 257. It's a 2000 watt but doesn't put out anywhere near that which I know. I bought it because my subs run 400 rms each and this lanzar is capable of putting out about 950 watts rms bridged.
The alternator is the factory one it's a 94 grand marquis so it should be putting out like what 135 amps or something.
Okay don't laugh. But it's a lanzar htg 257. It's a 2000 watt but doesn't put out anywhere near that which I know. I bought it because my subs run 400 rms each and this lanzar is capable of putting out about 950 watts rms bridged. The alternator is the factory one it's a 94 grand marquis so it should be putting out like what 135 amps or something.
There you go....Cheap amp an i bet you have no big 3 upgrade rite. I had a Boss "3k" amp that would pull on my elec system the same way. Believe it or not my much more powerful zxs1500.1 made my lights dim a lil less even thought it is 5x the amp. Just better quality i guess. So yea get an AGM an Big 3 then a real amp. Especially if u made a box. All 3 upgrades will run u $5-600 but if ur a BassHead its well worth it
Big 3 is done already and so your saying the autocraft battery won't work in the trunk as a second battery.
No its not a sealed battery, hella danger zone....thers ways around it, but that requires vents an all. Just invest in AGM batts
Alright lmao that's what I thought. Ok so I'm gonna look into getting a sealed battery and a new amp. Thanks a lot man!
I thought it say'd AutoZone....but that AutoCraft it an AGM is it not? If so it'l work in back....Tons if Tutorials on Youtube on how to hook up a 2nd batt
No it's definately not a sealed agm battery. It has the little caps you pour acid into.
Well yea....deff look in to an AGM i jus made a couple threads about High an Low end AGMs. I just got a DieHard for my Camry $175 w 3yr warranty
You need to troubleshoot. I assume you have an aftermarket HU. I'd start there by running a signal from a phone or ipod (etc) to the RCA outputs...
Yeah, put the probes on the power wire and ground wire of the amplifier. Multimeter on DC. Do not put it on the wires that go to your speakers. M
581
It's still a very small company that is growing. And growing has its challenges. He is very active on Facebook and does plenty of real test...
rada194
rada194
Miami, Florida
MakkMar10
maylar
    Jun 2, 2024
    Jun 1, 2024
