My very 1st Subwoofer enclosure build
Thanks. I was was going for that old Peavey Amp look, I believe that was the company. It's made of 3/4 MDF. I sealed it with a laquer based sanding sealer, put on 3 coats of filler primer and 3 coats of the purple base. All rustoleum 2x paint + primer. Then used the brush on to splatter. It took me 3 days to get up the nerve to do the splatter. Hahahaha
You did a nice job for your first box ever,well done that must knock hard.
10
Did you try the red on both sides, then the white on both sides. It may be a bad cable.
"I don't have any crossovers" You'll need one to filter out the low frequencies leading to your sub woofer. They'll produce no sound then...
14
GoT_2B_BuMpN
CarAudio.com Recruit
GoT_2B_BuMpN
No Conway, New Hampshire
Louisiana_CRX
maylar
    Jun 2, 2024
    Jun 1, 2024
