need an opinion on this idea.
sounds_explicit
basically i have a 20 tahoe with a lc8i and i have the unit under the seat. im building a bigger system so i want to mount this unit to a amp rack that is more sturdy. the unit will be moved about 4-5 feet back into the 3rd row. but i only ran enough input wire from speaker leads to under the seat. so my q is can i use some sort of separate channel distribution block for my speaker inputs from the block to the lc8i? that way i can use the rest of what wire i have instead of re wiring entire car again? id need 12 spots separate channel, put a terminal ring on the leads going to block terminal lead from block top lc8i. below is what i currently have set on getting. i just need to know if that would be a appropriate option .
https://www.amazon.com/dp/B01AHJV98A/?tag=caraudiocom-20
But since you guys are still here, I have another question. Now that I have a 3k amp, after I get my new battery and HO Alternator, I'll be in the...
272
20K
507
381
Very nice to hear you found what you needed to get your audio system/ect. up to your needs. we appreciate the information provided in this thread...
418
sounds_explicit
sounds_explicit
cleveland ohio
audiobaun
maylar
    Jun 2, 2024
    Jun 1, 2024
