Need Help on Amplifier for my subs
abecks44
I just bought an MTX amp and sub package from sonicelectronix that came with 2 12in subs. The amp that came with it, though, is terrible. It overheats if used to long, and cuts power to the subs. It also does not power the subs nearly what they can handle. So, my question is what amplifier should I buy ($200 or less) for my 2 12in terminator subs that will push them as hard as they can go without overpowering them. And of course not overheat or cut power to the subs... Any replies are appreciated, still pretty new with stereo systems.
Here are the specs to the subs:
2 12" Terminator Series Subwoofers Included
Power Handling:
Peak: 1200 watts per pair / 600 watts each sub
RMS: 400 watts per pair / 200 watts each sub
2" Aluminum single 4 ohms voice coil
Rubber Surround
Polypropylene Cone
MTX Audio Logo on Dustcap
48oz. Magnet
Frequency response: 37-150 Hz
1-year Manufacturer's warranty (on subwoofers only)
Set the amp up right and it should be fine
Pretty much this, something is obviously wrong. You (most likely) either have the subs wired incorrectly or you have poor power or ground connections somewhere.
Actually, I've read several reviews for this exact package stating that the amp overheats within minutes (mine takes about 20-30 of solid use), and completely fries itself within months. I would just like to know what kind of amp would best fit these subs.
Your box is set for a 2ohm load being 2 svc 4ohms subs. I suggest this MB Quart ONX1.1500D - ONYX Class D Monoblock Car Amplifier/Amp run it at 2ohms and set gains with dmm to 850rms or so. Wont need to do any electrical upgrades and will pound thoughs mtxs
If I run it at 2 ohms, wouldn't that be giving the subs 1000w RMS? So 500 RMS each? These subs are only rated for 200w RMS each, wouldn't that be bad for them?
Sorry, Reposted by accident, and I don't think I can delete it...
I'm not too sure I trust myself with installing an amp that could potentially break my speakers, I'm still pretty new with this. But I was browsing through sonicelectronix and found this amp, Kicker ZX400.1, would you recommend it for my subs?
Sorry I couldn't post a link straight to them, this site is not letting me post urls for some reason... But if you search "Kicker ZX400.1" in sonicelectronix, it's the first amp that pops up.
you could but you will be wanting more ,get an amp that will allow upgrades down the road.if this is your first system ,you wont have it long without going to something bigger
I probably won't be up grading my speakers anytime soon. For now, I would just like the best amp I can get for these subs. I'd gladly take a suggestion for an amp that would be used with better speakers that has a higher RMS output, but only if I get some pretty detailed information on how to set them up correctly...
941
You have a lot of great points stated here. I like it.. Nothing wrong with a little head room on any amplifier to run at lower gain settings to...
20
Here is my thought, theory. Those speakers are 80w rms. Half of that is 40w rms. Add the 40 to the 80 and you get 120w. Get an amp that is 120w...
I have 2 Sundown SA10v2 (1000w version) and just replaced my RF R1200 with a T-1500.1bd and OMG! I was considering Ampere Audio, JP23, Sundown...
Hmm. Maybe so. Ive never been more alert driving/riding than being on a Cycle man. Several think you just get on and ride away. A good set of...
26
5K
abecks44
abecks44
Spring, TX
audiobaun
Decebal
    Jun 10, 2024
