Need Subwoofer Recommendation
  • 4
biggz45
I'm looking for help on a subwoofer recommendation. Right now I have an enclosure that hits on all 4 corners and touches the trunk lid when it closes, so I can't go any bigger. I believe the box is about 2.3 cubes per chamber, so I am looking to get the maximum output for the space I'm limited to. Currently have 12s but could fit 15s. This would have to run off my DD M3a, so I've been looking at subs around 1400-1750w rms /ea. Prefer best bang for buck recommendations, but money isn't a huge issue. Thank you in advance //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
What subwoofers are you using now?
What is box tuned to?
What ohm load are you running them at currently?
If you have 12s and your box can't be any bigger how can you fit 15s? //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
Setup is about 7 years old - I have Alphasonik PSW912s now, current box was a prefab probably tuned roughly 40-42Hz but I could build new, running at .5 ohm.
Yeah I'd love to build, it's just a matter of finding the time.. It's been very slow progression on upgrading my current setup since I've first gotten it, but am to the point where I only need the end of the line with subs/box upgrade which will likely take me some time to actually do as well.
You have a lot of great points stated here. I like it.. Nothing wrong with a little head room on any amplifier to run at lower gain settings to...
20
509
381
biggz45
biggz45
United States
biggz45
maylar
    Jun 2, 2024
    Jun 1, 2024
