?? Need to know about the quality of these 2 amps ??
  • 2
BlancaLoca
I have 2 12' Pheonix Gold Radial SD competition subs. I need a 1000 watt + amp to push them. I recently bought a powerzone Crunch 1500.1 amp but am not sure if this will provide the good quality I am looking for. Also have had my eye on an O2/Q2 3000 watt amp but am not sure if this has good quality either.. also not sure if this will be too much to push these 2 12's. Not sure what the RMS rating is fo the subs but I was told I need a 1000 watt amp or better.
Also does anyone have any suggestions for a high quality amp that will push these subs and not blow a whole in my pocket...
Thanks for your help
Blane
509
382
Very nice to hear you found what you needed to get your audio system/ect. up to your needs. we appreciate the information provided in this thread...
418
625
BlancaLoca
BlancaLoca
Largo, FL
bunkrd you
maylar
    Jun 2, 2024
    Jun 1, 2024
