New setup.. Your thoughts?
Wire down to 2 ohms and that amp will be fine
As long as gains are set correctly. I'd use a DMM and set it to about 600w
---------- Post added at 11:38 PM ---------- Previous post was at 11:37 PM ----------
And if I don't go with an audiopipe' date=' what is another cheaper but quality amp that would work?[/quote']
Hifonics BRZ 1200
Maybe a used Alpine/Kicker/Rockford that's rated to output about 500w at 2 ohms
Hifonics BRZ 1200
That's kinda out of my price range for an amp haha.
Hifonics BRZ 1200
Honestly by ear would be fine with that amp only being rated for the rms of that sub and not knowing box specs anyway
I'd look for something used if I were you. I'm on a pretty tight budget too, I feel your pain
Haha exactly! But is the Boss amp that I have really that bad? I mean, I just want some quality bass in my car you know? I'm not planning on showing this off to anybody anyways..
It's awful to be honest. It'll put out nowhere near what it says it does and the signal it's putting out is probably distorted which could damage your sub
This is off topic, but my first setup I used an old Rockford Punch 100a2 and it pushed my two Kicker 12's pretty well. Is that amp even in the ballpark anymore?
Some guys like to collect some of the older RF stuff but not many guys here use it...
apsm's are great little amps at two ohms. I loved it when I had mine on a d4. At 1 ohm it sounded icky tho.
Id use them on a budget
This would go a long way to alleviating the dimming issue, up to around 4000 watts. It can handle 100A continuous and up to 285A 7 second burst...
707
I had some 9500 series 12s by MTX that were some slamming subs!! Should have kept those along with those torpedo RE XXX 12s
15
I am doing an all JL audio instal on my new F250 SD . I'm using a Audio Control LC 5i Pro with a JL Audio XDM 700/5 and C3-650's in all 4 doors...
984
Id sit down and figure out exactly what all you will be installing for amperage consumption and add another 10-15% amperage useage on top of that...
21
03Bonneville
03Bonneville
Lincoln, NE
audiobaun
maylar
    Jun 2, 2024
    Jun 1, 2024
