Nice & Cheap LiL Amp: Orion Cobalt CO3002
NIHL8ION
RUN ur car NOT ur mouth !
1,373
IlliNOISE
Item(s) for Sale: Used Orion Cobalt CO3002
Item(s) Description/Condition: Physical 9/10, Mechanical 10/10
Price: $50 Shipped (CONUS)
Shipping and Miscellaneous Item Information: ON ME (CONUS Only)
Specs:
*Cobalt 2-Channel Class A/B Car Amplifier
*RMS Power Rating:
- 4 ohms: 60 watts x 2 chan.
- 2 ohms: 80 watts x 2 chan.
- Bridged, 4 ohms: 160 watts x 1 chan.
*Max power output: 300 watts
*MOSFET power supply
*Tri-mode and bridgeable operation
*LED power and protect indicators
*Illuminated blue LED stripe design
*Selectable bass boost (0, 6, 12 dB)
*2/1 channel operation
*High-level inputs (signal sensing for automatic turn on)
*3-Way system protection circuitry (thermal, short circuit, and overload)
*Heavy duty aluminum alloy convection heatsink
*Chrome-plated RCA level input
*Chrome-plated screw terminals
*Input sensitivity (175mV-8V)
*Damping factor (>100)
*Continuously variable high-pass filter (50-500 Hz)
*Continuously variable low-pass filter (50-500 Hz, 2nd order 12 dB/octave)
*CEA-2006 compliant amplifier
*Frequency response: 20-30,000 Hz
*Dimensions: 7-15/16"L x 8-1/8"W x 2-1/8"H
BUMP - STILL HERE GUYS - I know someone here needs a good and cheap lil amp //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
I have the Original Box, Owners manual, High Level Input Plug, Etc. for this amp - C'Mon Y'all - I Know someone out there needs a small, reliable, lil 2 ch. Bridgeable amp for CHEAP - $50 Shipped
The 8's have a frequency response of 40hz and up. So I would cross them over at 60hz and up. And crossover my subs at 80hz. That way I would get a...
They have pre-cut wood if you pay extra at the hardware store. Just draw it out. But you'll have to pay extra. Then screw it in yourself...
151
382
NIHL8ION
NIHL8ION
IlliNOISE
NIHL8ION
maylar
    Jun 2, 2024
    Jun 1, 2024
