Please help with choosing an amp.
chrissavi
So I bought 2 12" Kicker Comp R DVC 2 ohm subwoofers a few weeks ago and I've been having problems figuring out what amp I would need to get loud bass out of then. I want as much bass as I get get out of them or close to it for a decent price. The subwoofers have a 1 ohm setting and a 4 ohm setting on an impedance switch which is very confusing to me.View attachment 26554125 I do not want to have to put in any extra batteries or alternators for this install. The car is a 2008 pontiac g6 gxp and I have already installed a 4 gauge wiring kit for an amp. I just need to know what amp I should run, what impedance I should set the subwoofers to, and how I should wire these 2 subwoofers to that amp. Any help is greatly apriciated!!!
The sound deadening is going to be more about preventing vibration from metal surfaces and adding unwanted noise. Does it have the JBL system...
It's called the K.I.S.S. preciniple ("Keep it simple, stupid!")... Takes the guesswork out of parallel/series wiring.
As for which signal to use, I tried all combinations and getting signal from the dash and front & rear doors is the only way the system sounded...
15
chrissavi
chrissavi
Fort Belvoir VA
macsdad
maylar
    Jun 2, 2024
    Jun 1, 2024
