Please help with coosing a new sub
Even though it says that much rms,it can take more. And any mono block with enough power. Audioque,powerbass,audiopipe... are some good cheap amps. Is your electrical upgraded at all?
No do not get caps. They are useless. Get a batt instead of a cap. What kind of car do you have and what year? Help to figure out what kind of alt you have. Either way you need to do the big 3
Not trying to post hijack.. but I see so many threads about having to recon these.. for a daily what is the max RMS power these things will take and still last? That's my question..
The sound deadening is going to be more about preventing vibration from metal surfaces and adding unwanted noise. Does it have the JBL system...
It's called the K.I.S.S. preciniple ("Keep it simple, stupid!")... Takes the guesswork out of parallel/series wiring.
As for which signal to use, I tried all combinations and getting signal from the dash and front & rear doors is the only way the system sounded...
15
awgg08
awgg08
Mission Viejo, CA
09civic
maylar
    Jun 2, 2024
    Jun 1, 2024
