Popping Noise and Vibrating Sound
I have 2 American Bass XFL 1544s ran to 1 ohm on a Hifonics Brutus 2k. Ive only had them about 2 months and they have just recently started to make a loud popping noise and a higher pitch hum. Sounds like a mechanical noise. I have my amp tuned right and gains set correctly. I was wondering what the sound may be? I'm not clipping them, and they are only 2 months old. What would fix this? I was really hoping that I wouldn't have to recone them 2 months into their lifespan...
Sounds like an electrical issue to me but possibly not. Are you familiar with alternator whine? Could that be the humming noise? And the pop is usually related to preouts or grounding but if it just started I can't be sure. Someone else will have an idea.
Its not alternator whine. Ive dealt with that before. and im familiar with it. It sounds like a mechanical noise. As if the actual cone is off
ringer ringer, chicken dinner... its your headunit. gotta upgrade mine as well, does the same thing, it cannot handle the additonal speakers, just...
Like @maylar said, delay the turn on to the amplifier only. 3 to 5 seconds should take care of it.
404
Wow that is very very odd. Could be the wiring harness from them. Check the wires and possibly reground the stereo to another bolt in back of the...
13
Maybe your amp gain is set too high, or wasn't set properly with the head units volume adjusted properly prior to setting the gain since you...
10
Yeah, I'd give them a call. They might replace it. If they do, that is huge CS. I've never known of any mfg to replace an amp because of complete...
17
skaterboyjt97
Roanoke, VA
Sguirrelfeather
maylar
    Jun 2, 2024
    Jun 1, 2024
