Precision Power Phantom13 13.25" Shallow Subwoofer
trumpet
Barry Schanz
2 in stock
Engineering Concept
The concept behind the PHANTOM 13 was not only to have the shallowest subwoofer on the market, but to also have a driver uniquely engineered to perform superior to all other drivers, in less space than all other drivers.
While the driver is not intended for SPL use and excessive bass amplitudes, it is in a category all by itself. It is shallower than any other driver on the market. This is a great engineering achievement and can definitely be appreciated by people with convertibles or other topless vehicles that cannot get any low bass response. The sound is phenomenal, taut, smooth and tonally accurate. PHANTOM 13 can be installed into an enclosure up to 1 cubic foot for even more bottom end extension. Bottom line, PHANTOM 13 will out perform woofers twice its size with perfect tonal accuracy in half the enclosure size.
Features and Specs
  • Custom Cast Aluminum Basket
  • Inverted Motor Structure
  • Polypropylene Coated Paper Cone
  • 2" Mounting Depth
  • 5" Voice Coil
  • 12 ga Direct Wire Terminal
  • Aluminum Voice Coil Former
  • Semi-Circular Basket Venting
T/S Params
  • Re 3.58
  • VC Dia 5"
  • Fo 28.81
  • (Z) 4 ohm
  • BL 10.15
  • Qms 6.01
  • Qes 1.19
  • Qts 0.99
  • Vas 59.20
  • Cms 162.38
  • Mms 188.25
  • Mmd 181.69
  • 1w/1m 82.65 dB
  • RMS power handling 200
  • Mounting Depth 2"
  • Piston Dia 11"
  • Cutout Dia 11.25"
$149
Free shipping to the Continental US
A QUOTE is required for all other locations.
My i-Trader feedback for caraudio.com - absolutely stellar record
Hhmmmm. 4 of these in 4cuft.... Lol. And vids around of these in action?
They just arrived to dealers within the last 2 weeks. I haven't seen any videos or even photos of these yet installed.
How does this sub compare to the JL 13TW5?
Totally different ballpark. TW5 is much more expensive, for good reasons. This Precision Power subwoofer is not going to sound like a 13TW5, but for what it is it does a good job.
Who had that Badazzed Astro Van?? I remember going to Austin seeing that ride. That thing made Earth pavement move about 50 ft before I got close...
489
Run the biggest AGM you can under the hood, the parallel runs to one of these - should be everything you need and then some...
711
trumpet
Barry Schanz
trumpet
St Cloud, MN
trumpet
maylar
    Jun 2, 2024
    Jun 1, 2024
