Rockford Fosgate Marine M162C
  • 2
Are the grills permanently attached on these? Do you have the seals and stainless screws?
Can you measure the total grille diameter as well as the magnet diameter? These look perfect for my toyhauler, but I have odd space limitations. Thanks
I would pull it and bench test it with a 12v battery. Ive had Bulbs burn out in the past and the amplifier works excellent. They will burn out at...
roger that, just got one from sonic electronix for $189. thanks for the help
18
Maybe ask RF tech support. I wasn’t able to find that either. Sonic electronics and Crutchfield just use the same description as the rf site. True...
After looking at amazon for kicker q product details, it showed rms of 1200@2ohm If you’re at 2ohm you’re not feeding it enough power. At 1ohm...
DaveAtRF
DaveAtRF
Arizona
DaveAtRF
