Should I use the double power input my amp brought?
Not to be that guy but............Clipping occurs when more power is required from an amplifier then it is able to deliver. Once the maximum amount of power supply voltage has been reached, it becomes impossible to amplify the incoming signal without compromising its form. This means that the signal is amplified but in a very distorted form.
The CT's are nice, That Sundown is a a frik'n beast!
882
2012 Nissan altima SR The trunk not ready to take back seats out I'm happy with the front and rear stage sub stage also I have a Sony DSX M80...
10
730
You can get close with tones, but music signal is all OVER the place in both frequencies and voltages. Like, if you listen to rap, the bass line...
846
Do you know what the box/port tuning is? And what is the db/octave slop on the crossovers being used? Setting the amp crossovers as open as...
MrPlebbian
MrPlebbian
Florida
KicktheSDbasshead
