Sound system problem
  • 2
I like to adjust the Aux though I use it usually.Not necessary though.
You should be fine/getting signal from HU to EQ
Its pretty simplistic/ not rocket science.
Have you tried another set if RCAs from the HU to EQ?
Possibly bad set?
Try each Ch/L&R to see if you get a signal from each on its own/Sound? and swap from Left to Right, checking sound from HU to EQ
No I Havent Tried A Different Set On Hu To Eq But I Will Thank You, & Everything Was New
I am hoping to hear its just a bad set of RCAs from the HU to the EQ or accidentally placing the RCA in the wrong spot off the HU to EQ.
Sometimes we get in a rush man,. Ive done it lots of times myself, and swore up and down I did this and that. LOL
Ive had a cheap pair of RCAs that got pinched pretty good and broke on backside of the HU from a tight fit and later used a set of 90* RCAs in the past in my 90 240SX
Hopefully It Is,
hopefully it is just that and yes the fader on the stereo and eq are centered
Update* thank u it was a bad set of rcas idk why it did not come to mind i thought it was everything else except a simple rca , thank You!
Sweet!! Im happy to hear that it was not a major issue.!! Very nice man. Thanks for letting us know what the culprit was!!
I suspect it's an ignition problem rather than a transmission problem. Start with the basics: plugs, wires, coils, check engine codes. Does the...
845
thats good to hear that sub/amp is good pair, well one of the front speakers on right side, im guessing it blew out because its the one that makes...
So I am planning to build a system in my Ford Excursion and can’t decide on whether I want to use an iPad mini with a sound processor behind it or...
Just got off the phone with Matt, that box isnt going to work, but ill put this out there..... https://www.soundoffaudio.com/ Anyone in south...
23
slvx3x_
slvx3x_
Nj
audiobaun
    May 31, 2024
    May 24, 2024
