Sundown Sax-1200d
n3w_3ra
Sundown Sax-1200d
8.5/10 Cosmetic 9.5/10 mechanical (used)
Rated power output
----RMS power, 2 ohm linkable/dual mono
2160W x 1CH
----RMS power, 1 ohm mono
1200W x 1CH
----RMS power, 2 ohm mono
720W x 1CH
----RMS power, 4 ohm mono
360W x 1CH
Signal to Noise Ratio >90dB
Low pass frequency crossover 35Hz~300Hz
Subsonic filter 10Hz~60Hz
Bass boost @ 45Hz 0~6dB
Phase shift control 0~180 degree
Frequency response 10Hz~350Hz (+/- 1dB)
T.H.D @ 4 ohm
Efficiency @ 4 ohm 86%
Fuse rating 40A x 3
Input Sensitivity 200mV to 6V (+/- 5%)
Dimensions 252(W) x 58(H) x 310(L)mm
I bought this amp about a month ago from another member on the forum. I hooked it up for 2 days, and then sold the subs in my car. Only reason I am selling is I saw the new crescendo amp and my alternator is too small, So i need a very efficient amp.
When the price on the crescendo goes up I will take this down.
215 shipped
Sundown Sax-1200d
Rated power output
2160W x 1CH
1200W x 1CH
720W x 1CH
360W x 1CH
T.H.D @ 4 ohm
Fuse rating 40A x 3
215 shipped
bass knob included?
605
10
My wife is gonna sh!t bricks when my subs get here. She doesn't know yet
19
n3w_3ra
n3w_3ra
S Florida
duhamell69
maylar
    Jun 2, 2024
    Jun 1, 2024
