Switching Head Units
  • 4
Currently I have a Pioneer DEH-P3700MP head unit in my truck, it doesn't have a 3.5 mm aux or a usb port though and i would like to upgrade. If I get another Pioneer Head unit is all I have to do is take out the old one unplug the wiring and plug it into the new one or do I have to rewire it for the new one?
Ok, do yall think its worth rewiring? The guy who helped me install it last time was ex-military and had taken classes that taught him how to do NASA level soldering, unfortunately I moved so i'm on my own on this one. Do yall suggest I try to learn how to solder or just twist the wires and put electrical tape or those clip things on them?
I do not advise you to solder wires together for a head unit,..especially inside a vehicle!You can twist the wires together and use tape,but i use the clear wire crimp caps,are cheap, and easy to use too.You can get a package at walmart/autozone or? for about 3-8.00? maybe,or if you just want to twist the wire together..I recommend 1/2inch heat shrink that works great for about 3.00 or so for a small package also,and seals nicely/forms tightly,and looks great when finished???Hope this has helped
Hello! i have too problems with head units, two cars, old mazda 323f ba and now mazda 6 2007r station. Problem is from lossing quality, poor bass...
Deff not going to hear much of a difference of the 4 ch amplifiers unless you are going to 100 rms per ch. With 10 watts, its just not worth the...
787
Yea, I'm running 6S2P. 12 cells total, 2 banks of 6. Resting voltage isn't as big of a concern, it's more about charging voltage. LTO shouldn't be...
10
Hi everyone... reaching out because I'm a beginner in car audio and need some help understanding how to correctly mount my new radio. I have a...
If you are metering outside the vehicle then I get it. The other option is the M1 has tons of slack on the cable. You can always stick it to the...
135
12K
bkelly
bkelly
College Station, TX
audiobaun
just call me KeV
    Jun 2, 2024
just call me KeV
    Jun 2, 2024
