Truck stutters
Its the drag created from your alternator. You don't feel it surge when the clutch is pushed in or when your in neutral right? I have a 5 speed in my Sonoma (4.3L v6) with dual alternators. When the amps are drawing a ton of power it puts more strain on your electrical and makes the alts work harder. If im just idling about 5mph in 1st gear and turn my system up a ton.... It almost stops the truck. But its definitely the alternator
I agree with this.
I have a 98 GTP just installed a 250a singer it started this but only at full tilt,never stalled the car but does choke it down
I agree with this.I have a 98 GTP just installed a 250a singer it started this but only at full tilt,never stalled the car but does choke it down
I'm wondering if u don't have the same issue I had. Something I did will using the help I was given was measure the resistance on te grounds. My oem ground strap was .025. I checked various places on the engine and it matched. After adding the 0ga grounds my engine and components sit at .03. Heck my meter from lead to lead is .02. So that might help u.
Its just the alternator picking up to supply the current draw.
Just like when giving someone a boost when you hook the jumper cables up you get a slight drop in rpms and can hear the alternator pickup some
front doors are subs...fyi Go with AudioControl 6x9 components up front and coaxials in the rear. You will be impressed with just changing to that.
579
Absolutely. I am always learning and think it's probably impossible to stop learning. I appreciate the advice and don't doubt for a second the...
56
4K
A lot of guys say I'm going low-end on cost but I see a lot of guys recommending just as cheap or cheaper products. Like MESO-6-5-3WAY-COM //...
13
Then I would get the dual 4 ohm subwoofers and wire it to 1 ohm like in the link below. Those subwoofers are 500 watts rms so running them at 1...
ok i get it dodge ram and full strip inside for second skin . power is run down drivers side and speaker wire is run down passanger side thank you
voltagexdt
voltagexdt
South Georgia
garychurch84
maylar
    Jun 2, 2024
    Jun 1, 2024
