Tsunami AMP01BL 1/0 AWG OFC amplifier power kit
  • 1
trumpet
Barry Schanz
New
  • 17 feet (5.18m) 1/0 gauge blue power cable
  • 3 feet (914mm) 1/0 gauge silver ground cable
  • 17 feet (5.18m) 18 gauge blue remote turn-on wire
  • 1/0 gauge 1 position ANL fuse holder
  • 250 AMP ANL fuse
  • (2) 1/0 gauge to 5/16 inch (7.9mm) nickel-plated ring terminals
  • Blue and silver insulators
  • Heavy duty 1/0 gauge to 5/16 inch (7.9mm) nickel-plated ring terminal
  • Clear insulator
  • Heavy duty nickel-plated ground terminal
  • Hardware Pack (10) 6 inch (152mm) cable ties (6) Phillips nickel-plated panhead screws
  • (2) Red vinyl nickel-plated spade terminals
  • (2) Blue vinyl butt connectors
  • 1/0 gauge snap grommet
$94.99 shipped within the Continental US
Free shipping to the lower 48 states.
All other locations require a quote.
Need RCAs, speaker wire, 4 AWG OFC wire, battery terminals, a line driver, power/ground distribution block? If I missed anything you need feel free to ask!
It should work well enough for you to get solid connections. That’s about the same price I paid for this one, and I‘d bet all the cheaper...
  • Locked
Thanks for the quick rep and it was great chatting w/ you. Good luck w/ what we discussed. It rare but sometimes I stumble across odd and ends...
18
Run 4g for power (or 1/0 if you can). There is no downside to bigger wire, and you won't have to replace it if (when) you go bigger. Speaker wire...
906
trumpet
Barry Schanz
trumpet
St Cloud, MN
trumpet
Decebal
    Jun 10, 2024
