What amp should i get?!
Vice
im really new to car audio and im just not sure what kind of amp i should get. I have a soundquebed hdc15 d2 and am looking to spend around $200 to $250. The sub pushes around 1200rms so im looking for something that can put out close to that. Any suggestions?
And your sub doesn't "push" any power ..... it is rated to accept XXXX amount of power from an amplifier .....
You could look at the PPI amp already listed, a AB ph4000d, a MA N4, a PPI ph1000d, ect ..... may amps to choose from in that range ....
Pioneer lists the wattage different than sonic. Pioneer says That amp listed will do great with these speakers. You can play em at 125w no...
Have you check to see if the prefab would fit...
13
For the sub you want to run.. The 700.1 will be more than enough power and enough Head room for that sub. For the Price? And the sub you are...
13
Your skar amp will catch on fire if you go full power?
I'll suggest a JP8 amplifier. I believe you can wire your sub to 2 ohm. It's Dual voice coil 4 ohm, correct? JP8 @ 2 ohm does 900 watts.
Vice
Vice
New York (upstate)
Boominburban
