Where the wires at?
There's an opening big enough to get them in under the heater core box...If i had used round wire instead of flat wire ...I could've ran 8 runs...I have an equal number of grounds since its a unibody...and weak trunk grounds
fLat wire :O
Check under the body of your car, running down the doors to see if you could tuck the wire up in there. That's how we did my friends Altima. We ran it behind the plastic of the tire well and drilled a hole through the trunk. My homey just bought a Tahoe and he ran the wire on his frame rail. I don't know where he drilled through to get it out.
Idk if I wanna drill but if I have to yolo haha. Imma check my car today to see where I can put those wires because I want to do around 2+ runs of 4/0 welding since its cheaper than ca 1/0.
4 runs in a 08impala under passenger seats .going thru big rubber grommet behind glove box
^ that is awesome thank you. I hope I can find more grommets. The only one i've found so far is the main firewall but it's being mandingo'd by my single 4/0 so I can't go in there again (poor thing)
One of my under hood shots ....
Nice
Eggroll
RingsOfSaturn>your music
Eggroll
Death Metal > Your Music
Eggroll
