WTT Soundstream USA 305 5 CHANNEL AMPLIFIER OLD SCHOOL SQ
  • 2
johnjv29
1. Product:
Soundstream USA 305
2. Specs:
Specs:
SPECIFICATIONS
POWER OUTPUT
CROSSOVER SPECIFICATIONS
High Pass: 12 dB/octave, factory set at 150 Hz (non-variable)
Low Pass: 24 dB/octave, factory set at 75 Hz (Variable by S.I.P.)
(800 Hz "bypass" S.I.P. included)
DIMENSIONS
USA•305: 14-1/4” W x 8-3/16” D x 2-3/16” H
SERVICE
Your Soundstream amplifier is protected by a limited warranty. Please read
the enclosed warranty card.
THD
Signal to Noise > 90 dB
Frequency Response 20 Hz to 20 kHz +/- 0.5 dB
Stereo Separation > 90 dB
Damping > 200
Input Sensitivity 100 mV - 2.5 V
Input Impedance 12 k ohms
USA•305
Power at 4 ohms 35w x 4 +
100w x 1
Power at 2 ohms 60w x 4 +
160w x 1
Bridged power at 4 ohms 120w x 2
This amp is definately underrated and has that clean oldschool power!!
3. Description/Condition:
This amp is in good condition for its age,its not perfect and has a few scratches but no dents,bends etc.This amp works great and sounds excellent.This can be used as just a 4 channel or if you want to run your whole setup,the sub channel can be used.I just dont need it,I am running a A/D/S P840.2 and dont need a second amp..
4. Price: :
$125+shipping OBO Make an offer or possibly trade..
Mine connected just fine, but I liked the onboard menu better and deleted the app.
45
4K
Very true statement here. Can also possibly damage the subs if not used properly,and may even cook an amplifier in the process possibly. It may be...
johnjv29
johnjv29
kentwood mi
johnjv29
maylar
    Jun 2, 2024
    Jun 1, 2024
