Amp turns on, won't power subs.
  • 6
I have a Legacy LA770 500WX2 CH amplifier with two Memphis 12" subs. The amp will power on and everything, but I have no sound out of the subs. I've tried so many things, different RCA cables, different ground, and everything. The biggest thing here is that I hooked up the subs to another amplifier and they worked fine, they hit hard and everything. I had everything set up the same. So what is my problem?
I mean the RCA's on the amp itself (The input on the amplifier). Sorry to say it, but Legacy is near the bottom for quality of construction. I have one in my closet next to a Pyramid amplifier (First two my father bought when I was in highschool). I wouldn't be surprised if it was defective.
It might be "ghetto" by today's standards but I used to run a wire off the battery to a switch then to the amp...back in my youth the Police liked...
15
4K
148
381
  • Locked
684
Amp
498
ralph42794
ralph42794
Parkersburg, West Virginia
Pataforce8
maylar
    Jun 2, 2024
    Jun 1, 2024
