Help me make a setup
OP has 2 posts and is being advised by Crispin, who, if I am not mistaken has made several dumb posts in the past, so he shouldn't be the one to post advice.....Just saying.
at least about car audio,maybe about being a total f..n idiot would work for him
cuz that guy is giving you sh..y advice.1st of all if you have to run those woofers get a good amp between 800- 1000 watts rms clean power and the woofers will last a while .pyramid and boss are flee market crap.... try a massive nano n2 amp,or sundown,audioque,or even an ab ,those are just a few great amps that will do nicely in your set up.as for box build yourself a ported one ,if you dont know how check around on here some one may be able to help.we're not really talking sh.t we are just trying to help you out so you dont spend your cash and end up with total junk, and be pissed
//content.invisioncic.com/y282845/emoticons/smash.gif.499e08a4a35ffaf54f4c8194fb8fe8ed.gif:smash://content.invisioncic.com/y282845/emoticons/smash.gif.499e08a4a35ffaf54f4c8194fb8fe8ed.gif:smash://content.invisioncic.com/y282845/emoticons/smash.gif.499e08a4a35ffaf54f4c8194fb8fe8ed.gif^^^ agreed cased closed, by the way if you are goiung to build an enclosure use MDF
wow, how the heck is he going to do that with those crappy subs? He needs the 5000 watt subs to be the king of the block. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
5000 watt boss subs with a huge magnet!!!!
oh btw, those cvr's are only 400 watts rms each. For a good amp, you can try kicker, audioque, sundown.. etc.
But tbh, i wouldnt spend too much on an amp for those subs.
Id sit down and figure out exactly what all you will be installing for amperage consumption and add another 10-15% amperage useage on top of that...
21
One Of my favorite sites to gain some information over the years. Excellent! I would deff. Bookmark it!!
38
A lot of guys say I'm going low-end on cost but I see a lot of guys recommending just as cheap or cheaper products. Like MESO-6-5-3WAY-COM //...
13
I would add an ANL Fuse @the amplifier supply with its recommended 100 ANL fuse, and Keep the 120-150 @the Battery...
CelicaBASS
CelicaBASS
illinois
>>SQL<<
